Ir para o conteúdo principal
LG Enact Keyboard Replacement
O que você precisa
  1. LG Enact Keyboard Replacement, Battery: passo 1, imagem 1 %32 LG Enact Keyboard Replacement, Battery: passo 1, imagem 2 %32 LG Enact Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Keyboard Replacement: passo 2, imagem 1 %32 LG Enact Keyboard Replacement: passo 2, imagem 2 %32 LG Enact Keyboard Replacement: passo 2, imagem 3 %32
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Keyboard Replacement, Speaker: passo 3, imagem 1 %32
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Keyboard Replacement: passo 4, imagem 1 %32 LG Enact Keyboard Replacement: passo 4, imagem 2 %32
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Keyboard Replacement, Midframe: passo 5, imagem 1 %32 LG Enact Keyboard Replacement, Midframe: passo 5, imagem 2 %32
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Keyboard Replacement: passo 6, imagem 1 %32
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Keyboard Replacement, Motherboard: passo 7, imagem 1 %32 LG Enact Keyboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Keyboard Replacement: passo 8, imagem 1 %32 LG Enact Keyboard Replacement: passo 8, imagem 2 %32
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Keyboard Replacement, Charging Port: passo 9, imagem 1 %32 LG Enact Keyboard Replacement, Charging Port: passo 9, imagem 2 %32
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
  10. LG Enact Keyboard Replacement, Keyboard: passo 10, imagem 1 %32 LG Enact Keyboard Replacement, Keyboard: passo 10, imagem 2 %32 LG Enact Keyboard Replacement, Keyboard: passo 10, imagem 3 %32
    • Gently remove the blue metal plate using an iFixit opening pick.
    • Gently remove the black plastic from inside the battery compartment.
  11. LG Enact Keyboard Replacement: passo 11, imagem 1 %32
    • Remove seven 1.2 mm screws with a Phillips #00 screwdriver.
  12. LG Enact Keyboard Replacement: passo 12, imagem 1 %32
    • Remove the ribbon cable from the battery compartment.
  13. LG Enact Keyboard Replacement: passo 13, imagem 1 %32 LG Enact Keyboard Replacement: passo 13, imagem 2 %32 LG Enact Keyboard Replacement: passo 13, imagem 3 %32
    • Remove the plastic half containing the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
mad
Membro desde: 09/12/23
136 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 91
