Ir para o conteúdo principal
LG Enact Charging Port Replacement
O que você precisa
  1. LG Enact Charging Port Replacement, Battery: passo 1, imagem 1 %32 LG Enact Charging Port Replacement, Battery: passo 1, imagem 2 %32 LG Enact Charging Port Replacement, Battery: passo 1, imagem 3 %32
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Charging Port Replacement: passo 2, imagem 1 %32 LG Enact Charging Port Replacement: passo 2, imagem 2 %32 LG Enact Charging Port Replacement: passo 2, imagem 3 %32
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Charging Port Replacement, Speaker: passo 3, imagem 1 %32
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Charging Port Replacement: passo 4, imagem 1 %32 LG Enact Charging Port Replacement: passo 4, imagem 2 %32
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Charging Port Replacement, Midframe: passo 5, imagem 1 %32 LG Enact Charging Port Replacement, Midframe: passo 5, imagem 2 %32
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Charging Port Replacement: passo 6, imagem 1 %32
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Charging Port Replacement, Motherboard: passo 7, imagem 1 %32 LG Enact Charging Port Replacement, Motherboard: passo 7, imagem 2 %32
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Charging Port Replacement: passo 8, imagem 1 %32 LG Enact Charging Port Replacement: passo 8, imagem 2 %32
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Charging Port Replacement, Charging Port: passo 9, imagem 1 %32 LG Enact Charging Port Replacement, Charging Port: passo 9, imagem 2 %32
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 70
