Ir para o conteúdo principal
LG EnV VX9900 LCD Screen Replacement
O que você precisa
  1. LG EnV VX9900 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Place the phone so the screen side is facing down.
    • Locate the latch at the end of the phone, opposite of the camera.
  2. LG EnV VX9900 LCD Screen Replacement: passo 2, imagem 1 %32
    • Push/pull the latch away from the camera, causing the battery to pop out.
  3. LG EnV VX9900 LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the battery.
  4. LG EnV VX9900 LCD Screen Replacement, Circuit Board and Full Key Board: passo 4, imagem 1 %32 LG EnV VX9900 LCD Screen Replacement, Circuit Board and Full Key Board: passo 4, imagem 2 %32
    • Remove the 5 screw covers on the back of the phone using a Push Pin.
  5. LG EnV VX9900 LCD Screen Replacement: passo 5, imagem 1 %32
    • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
  6. LG EnV VX9900 LCD Screen Replacement: passo 6, imagem 1 %32 LG EnV VX9900 LCD Screen Replacement: passo 6, imagem 2 %32
    • Open the phone.
  7. LG EnV VX9900 LCD Screen Replacement: passo 7, imagem 1 %32 LG EnV VX9900 LCD Screen Replacement: passo 7, imagem 2 %32
    • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
    • Prying open the part just to the left of the right hinge can be difficult.
    • Remove the back colored casing and set it to the side.
  8. LG EnV VX9900 LCD Screen Replacement: passo 8, imagem 1 %32 LG EnV VX9900 LCD Screen Replacement: passo 8, imagem 2 %32
    • Gently pry and detach the connection located near the hinge with fingers.
  9. LG EnV VX9900 LCD Screen Replacement: passo 9, imagem 1 %32 LG EnV VX9900 LCD Screen Replacement: passo 9, imagem 2 %32
    • The circuit board and the key board will be attached, as shown in the second picture.
    • Lift them both out from the rest of the phone.
    • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
  10. LG EnV VX9900 LCD Screen Replacement, LCD Screen: passo 10, imagem 1 %32
    • After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
  11. LG EnV VX9900 LCD Screen Replacement: passo 11, imagem 1 %32
    • Careful! The paint is easy to scratch.
    • Remove the 4 screw covers from top piece of phone by using a Push Pin.
  12. LG EnV VX9900 LCD Screen Replacement: passo 12, imagem 1 %32
    • Remove the four 3.44 mm screws that were under the covers using a Phillips #00 Screwdriver.
  13. LG EnV VX9900 LCD Screen Replacement: passo 13, imagem 1 %32 LG EnV VX9900 LCD Screen Replacement: passo 13, imagem 2 %32 LG EnV VX9900 LCD Screen Replacement: passo 13, imagem 3 %32
    • Be careful while breaking the adhesive connecting the speaker and the casing in the following sub step so that you do not tear any wires.
    • Pry open the colored casing using the Plastic Pry Tool.
    • Remove the number pad and place it to the side.
  14. LG EnV VX9900 LCD Screen Replacement: passo 14, imagem 1 %32 LG EnV VX9900 LCD Screen Replacement: passo 14, imagem 2 %32
    • Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner.
  15. LG EnV VX9900 LCD Screen Replacement: passo 15, imagem 1 %32
    • The pieces connected by wires are magnets and are removable.
    • Remove the LCD Screen.
Conclusão
Equipe
Cal Poly, Team 15-15, Forte Spring 2012 Membro de Cal Poly, Team 15-15, Forte Spring 2012
CPSU-FORTE-S12S15G15
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,300
