Ir para o conteúdo principal
LG EnV Touch VX11000 Volume and Camera Buttons Replacement
O que você precisa
  1. LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: passo 2, imagem 1 %32
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: passo 3, imagem 1 %32 LG EnV Touch VX11000 Volume and Camera Buttons Replacement: passo 3, imagem 2 %32
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Volume and Camera Buttons: passo 4, imagem 1 %32 LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Volume and Camera Buttons: passo 4, imagem 2 %32
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: passo 5, imagem 1 %32
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: passo 6, imagem 1 %32 LG EnV Touch VX11000 Volume and Camera Buttons Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
Conclusão
Rachel Smith
Membro desde: 09/30/13
593 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-2, Forte Fall 2013 Membro de Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 266
