Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
Lift the back plastic cover off by moving the opening tool around the edges of the phone.
Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
Pull off the back plastic panel.
Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
Disconnect the three ribbon connectors from the motherboard.
Remove the LED.
Remove the camera connector.
Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
Use the opening tool to lift up the green logic board in all areas and remove it.
Peel off the gold and green tape near the bottom of the phone.
Peel off the blue tape covering the speaker connector.
Peel off the gold tape to the left of the earpiece speaker.
Lift up the orange ribbon cable in the bottom left corner of the device.
Peel off the small piece of gold tape underneath the orange component back.
Undo the clips that attach the black plastic strip to the frame of the phone.
Pry the plastic strip away from the phone, using an opening tool, until it detaches.
Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
Rotate the phone upside down with the back facing you.
Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
Remove the frame from the plastic panel.
Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
