Introdução
If the QWERTY silicon keypad is worn out or damaged, it is replaceable. It requires time and a lot of disassembling.
O que você precisa
Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
Uma outra pessoa concluiu este guia.
