Ir para o conteúdo principal
LG Cosmos Silicon Keypad Replacement
O que você precisa
  1. LG Cosmos Silicon Keypad Replacement, Battery: passo 1, imagem 1 %32
    • Apply an upward force to slide the back cover off.
    Pergunte ao FixBot
    Comentar
  2. LG Cosmos Silicon Keypad Replacement: passo 2, imagem 1 %32
    • Use your finger to push down on the top of the battery and pull it out.
    Pergunte ao FixBot
    Comentar
  3. LG Cosmos Silicon Keypad Replacement, Rear Case: passo 3, imagem 1 %32
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
    Pergunte ao FixBot
    Comentar
  4. LG Cosmos Silicon Keypad Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry the rear case loose.
    Pergunte ao FixBot
    Comentar
  5. LG Cosmos Silicon Keypad Replacement: passo 5, imagem 1 %32
    • Once the rear case is loose, lift it from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  6. LG Cosmos Silicon Keypad Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
    Pergunte ao FixBot
    Comentar
  7. LG Cosmos Silicon Keypad Replacement: passo 7, imagem 1 %32
    • Use the plastic opening tool to pry the motherboard loose.
    Pergunte ao FixBot
    Comentar
  8. LG Cosmos Silicon Keypad Replacement: passo 8, imagem 1 %32
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
    Pergunte ao FixBot
    Comentar
  9. LG Cosmos Silicon Keypad Replacement: passo 9, imagem 1 %32
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
    Pergunte ao FixBot
    Comentar
  10. LG Cosmos Silicon Keypad Replacement: passo 10, imagem 1 %32
    • Use your finger to pull the flex cable out from its connector.
    Pergunte ao FixBot
    Comentar
  11. LG Cosmos Silicon Keypad Replacement: passo 11, imagem 1 %32
    • Pull the motherboard away from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  12. LG Cosmos Silicon Keypad Replacement, Silicon Keypad: passo 12, imagem 1 %32
    • Lift the silicon keypad away from the rest of the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Johnny Phane
Membro desde: 04/15/13
91 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-63, Johann Spring 2013 Membro de Cal Poly, Team 13-63, Johann Spring 2013
CPSU-JOHANN-S13S13G63
3 Membros
Autoria de 14 guias
1Comentário do guia
Steps 10 and 11 are not necessary for replacing just the silicone keypad. As long as you are careful not to pull on the motherboard, once you have the motherboard rotated up, you are able to replace the silicone keypad directly from that point.
Randy - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Ao todo: 1,159
