Introdução
If you have damaged your side case, it is possible to replace. It requires time, a lot of disassembling, and includes many small parts.
O que você precisa
Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
Quase terminado!
Conclusão
