Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Rear case replacement will only require the removal of the battery and six screws, but prying the case loose may take a few minutes.
O que você precisa
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
