Ir para o conteúdo principal
LG Cosmos 2 Motherboard Replacement
O que você precisa
  1. LG Cosmos 2 Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Cosmos 2 Motherboard Replacement, Battery: passo 1, imagem 2 %32 LG Cosmos 2 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Motherboard Replacement: passo 2, imagem 1 %32 LG Cosmos 2 Motherboard Replacement: passo 2, imagem 2 %32 LG Cosmos 2 Motherboard Replacement: passo 2, imagem 3 %32
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Motherboard Replacement, Rear Case: passo 3, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Motherboard Replacement: passo 4, imagem 1 %32 LG Cosmos 2 Motherboard Replacement: passo 4, imagem 2 %32 LG Cosmos 2 Motherboard Replacement: passo 4, imagem 3 %32
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 Motherboard Replacement: passo 6, imagem 1 %32
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 Motherboard Replacement: passo 7, imagem 1 %32 LG Cosmos 2 Motherboard Replacement: passo 7, imagem 2 %32
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 Motherboard Replacement: passo 8, imagem 1 %32 LG Cosmos 2 Motherboard Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the motherboard from the front case.
Conclusão
Nick White
Membro desde: 10/18/13
866 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 13-1, Benson Fall 2013 Membro de Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,147
