Ir para o conteúdo principal
LG CineBeam Wi-Fi and Bluetooth Card Replacement
O que você precisa
  1. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Bottom Plate: passo 1, imagem 1 %32
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
  2. LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 2, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 2, imagem 2 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 2, imagem 3 %32
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
  3. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: passo 3, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: passo 3, imagem 2 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: passo 3, imagem 3 %32
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
  4. LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 4, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 4, imagem 2 %32
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
  5. LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 5, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 5, imagem 2 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 5, imagem 3 %32
    • Lift the motherboard out of the casing.
  6. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: passo 6, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: passo 6, imagem 2 %32
    • Use your fingers to lift the speaker from the casing.
  7. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: passo 7, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: passo 7, imagem 2 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: passo 7, imagem 3 %32
    • Turn the device over so the power button is facing up.
    • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
  8. LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 8, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 8, imagem 2 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement: passo 8, imagem 3 %32
    • Using an iFixit opening tool, remove the battery.
  9. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: passo 9, imagem 1 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: passo 9, imagem 2 %32 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: passo 9, imagem 3 %32
    • Using an iFixit opening tool, move the plastic clip on the right side of the board out of the way.
    • Using an iFixit opening tool, pry the Wi-Fi and Bluetooth card out of its socket.
Conclusão
John Dalton
Membro desde: 03/23/22
393 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-5, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-5, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 193
