Ir para o conteúdo principal
LG Chocolate Sliding Mechanism Replacement
O que você precisa
  1. LG Chocolate Sliding Mechanism Replacement, Battery: passo 1, imagem 1 %32 LG Chocolate Sliding Mechanism Replacement, Battery: passo 1, imagem 2 %32
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    Pergunte ao FixBot
    Comentar
  2. LG Chocolate Sliding Mechanism Replacement, Back Cover: passo 2, imagem 1 %32
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Chocolate Sliding Mechanism Replacement: passo 3, imagem 1 %32 LG Chocolate Sliding Mechanism Replacement: passo 3, imagem 2 %32 LG Chocolate Sliding Mechanism Replacement: passo 3, imagem 3 %32
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
    Pergunte ao FixBot
    Comentar
  4. LG Chocolate Sliding Mechanism Replacement, Sliding Front: passo 4, imagem 1 %32
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    Pergunte ao FixBot
    Comentar
  5. LG Chocolate Sliding Mechanism Replacement: passo 5, imagem 1 %32 LG Chocolate Sliding Mechanism Replacement: passo 5, imagem 2 %32
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    Pergunte ao FixBot
    Comentar
  6. LG Chocolate Sliding Mechanism Replacement: passo 6, imagem 1 %32 LG Chocolate Sliding Mechanism Replacement: passo 6, imagem 2 %32
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    Pergunte ao FixBot
    Comentar
  7. LG Chocolate Sliding Mechanism Replacement: passo 7, imagem 1 %32
    • Pry off the back cover from the front of the case using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  8. LG Chocolate Sliding Mechanism Replacement, Sliding Mechanism: passo 8, imagem 1 %32
    • Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
    Pergunte ao FixBot
    Comentar
  9. LG Chocolate Sliding Mechanism Replacement: passo 9, imagem 1 %32
    • Remove sliding mechanism.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Thomas
Membro desde: 01/18/13
91 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 19-46, Regan Winter 2013 Membro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 47
Ao todo: 785
