Ir para o conteúdo principal
LG Chocolate Motherboard Replacement
O que você precisa
  1. LG Chocolate Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Chocolate Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Motherboard Replacement, Back Cover: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Motherboard Replacement: passo 3, imagem 1 %32 LG Chocolate Motherboard Replacement: passo 3, imagem 2 %32 LG Chocolate Motherboard Replacement: passo 3, imagem 3 %32
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 LG Chocolate Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Carefully pry the motherboard off of the back case
Conclusão
Maci Miri
Membro desde: 01/18/13
39 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-46, Regan Winter 2013 Membro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
Membros da 4
Autoria de 22 guias
Um comentário
is there any way to get information off of a motherboard with a chargeport that is broken?
Robert Gietzen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 790
