Ir para o conteúdo principal
LG Chocolate Back Cover Replacement
O que você precisa
  1. LG Chocolate Back Cover Replacement, Battery: passo 1, imagem 1 %32 LG Chocolate Back Cover Replacement, Battery: passo 1, imagem 2 %32
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Back Cover Replacement, Back Cover: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Back Cover Replacement: passo 3, imagem 1 %32 LG Chocolate Back Cover Replacement: passo 3, imagem 2 %32 LG Chocolate Back Cover Replacement: passo 3, imagem 3 %32
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
Conclusão
Forrest Lipske
Membro desde: 01/18/13
49 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 19-46, Regan Winter 2013 Membro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
Membros da 4
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 358
