Introdução
Use this guide to replace the motherboard. Be prepared to handle small screws and delicate electronic connections.
O que você precisa
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
Use tweezers to remove the music button found on the side of the phone.
Quase terminado!
Conclusão
