Introdução
Use this guide to replace the motherboard of the LG Chocolate 3. Be prepared to handle small screws and delicate electronic connections. Be sure to pay attention to what shouldn't be disconnected. Some parts may be viable to fall out during this process; it is important to reassemble them during the motherboard replacement process.
O que você precisa
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to remove the music button found on the side of the phone.
