Introdução
Ir your keypad is not working anymore and you want to easily change it at home, use this guide to replace a damaged or malfunctioning LG Chocolate 3 Keypad.
O que você precisa
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
To reassemble this device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
