Introdução
This guide explains how to remove the front plastic screen covering from the phone. This is a fairly simple guide for the LG CU515 SKU 64743 Device. Removing the front screen covering will require only a plastic pry tool. This guide will take you through each step in detail so as to make the process as easy as possible.
O que você precisa
