Introdução
This guide teaches a user how to remove the battery of the LG CU515 SKU 64743 device. The steps outlined here should be fairly simple to follow. This guide is the second step in beginning to take apart the device.
Ferramentas
Não são necessárias ferramentas.
Peças
Não são necessárias peças.
  1. Locate the raised tab at the top of the back cover. Holding the phone in one hand and using your thumb on your other hand, push down on the tab until the cover detaches from the phone. Slide the cover down until it is completely removed from the phone.
    • Locate the raised tab at the top of the back cover.
    • Holding the phone in one hand and using your thumb on your other hand, push down on the tab until the cover detaches from the phone.
    • Slide the cover down until it is completely removed from the phone.
  2. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone. Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone. Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone.
    • Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone.
Conclusão
Josh Davis
301 reputação
3 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Todo: 118
