Ir para o conteúdo principal
LG CU515 Keypad Replacement
O que você precisa
  1. LG CU515 Keypad Replacement, Battery: passo 1, imagem 1 %32 LG CU515 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Keypad Replacement: passo 2, imagem 1 %32 LG CU515 Keypad Replacement: passo 2, imagem 2 %32 LG CU515 Keypad Replacement: passo 2, imagem 3 %32
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Keypad Replacement, Motherboard: passo 3, imagem 1 %32
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Keypad Replacement: passo 4, imagem 1 %32
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Keypad Replacement: passo 5, imagem 1 %32 LG CU515 Keypad Replacement: passo 5, imagem 2 %32 LG CU515 Keypad Replacement: passo 5, imagem 3 %32
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Keypad Replacement: passo 6, imagem 1 %32
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Keypad Replacement: passo 7, imagem 1 %32
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Keypad Replacement: passo 8, imagem 1 %32
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
  9. LG CU515 Keypad Replacement, Keypad: passo 9, imagem 1 %32
    • Push keypad up and out of the phone casing until they separate.
    • Replace with new keypad.
Conclusão
Equipe
Cal Poly, Team 21-55, Johann Spring 2013 Membro de Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 68
Ao todo: 455
