Ir para o conteúdo principal
LG CG225 Keyboard Replacement
O que você precisa
  1. LG CG225 Keyboard Replacement, Rear Cover: passo 1, imagem 1 %32
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Keyboard Replacement: passo 3, imagem 1 %32
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Keyboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Keyboard Replacement: passo 5, imagem 1 %32
    • Using a small plastic opening tool, remove the motherboard.
  6. LG CG225 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
Conclusão
Mackenzie
Membro desde: 02/13/14
1 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 1-3, Meza Spring 2014 Membro de Ohio State, Team 1-3, Meza Spring 2014
OSU-MEZA-S14S1G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 287
