Ir para o conteúdo principal
LG CG180 Circuit Board Replacement
O que você precisa
  1. LG CG180 Circuit Board Replacement, Battery: passo 1, imagem 1 %32
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Circuit Board Replacement: passo 2, imagem 1 %32
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Circuit Board Replacement: passo 3, imagem 1 %32 LG CG180 Circuit Board Replacement: passo 3, imagem 2 %32
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Circuit Board Replacement: passo 4, imagem 1 %32
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Circuit Board Replacement: passo 5, imagem 1 %32
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Circuit Board Replacement, Hardshell Case: passo 6, imagem 1 %32
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Circuit Board Replacement: passo 7, imagem 1 %32
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Circuit Board Replacement: passo 8, imagem 1 %32 LG CG180 Circuit Board Replacement: passo 8, imagem 2 %32
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Circuit Board Replacement: passo 9, imagem 1 %32 LG CG180 Circuit Board Replacement: passo 9, imagem 2 %32
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Circuit Board Replacement: passo 10, imagem 1 %32
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Circuit Board Replacement: passo 11, imagem 1 %32
    • The hardshell case is separated from the rest of the phone.
  12. LG CG180 Circuit Board Replacement, Keypad: passo 12, imagem 1 %32 LG CG180 Circuit Board Replacement, Keypad: passo 12, imagem 2 %32
    • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
  13. LG CG180 Circuit Board Replacement, Display: passo 13, imagem 1 %32
    • Place the circuit board with the display facing downward.
  14. LG CG180 Circuit Board Replacement: passo 14, imagem 1 %32
    • Use thumb to release both white clips at the top of the circuit board.
    • Be careful with the display because it is still attached by electrical tape.
  15. LG CG180 Circuit Board Replacement: passo 15, imagem 1 %32 LG CG180 Circuit Board Replacement: passo 15, imagem 2 %32
    • Once both clips are released, turn over the circuit board so that the display is facing upward.
    • Carefully lift the display from the left side and open to the right.
  16. LG CG180 Circuit Board Replacement: passo 16, imagem 1 %32
    • Carefully remove the electrical tape from the display.
  17. LG CG180 Circuit Board Replacement: passo 17, imagem 1 %32
    • The display is disconnected from the circuit board.
  18. LG CG180 Circuit Board Replacement, Circuit Board: passo 18, imagem 1 %32
    • The circuit board is separated from the rest of the phone.
Conclusão
Alex Jacobs
Membro desde: 01/21/10
5 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-42, Regan Winter 2010 Membro de Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 2,828
