Ir para o conteúdo principal
LG CF360 Rear Speaker Replacement
O que você precisa
  1. LG CF360 Rear Speaker Replacement, Battery: passo 1, imagem 1 %32 LG CF360 Rear Speaker Replacement, Battery: passo 1, imagem 2 %32
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Rear Speaker Replacement: passo 2, imagem 1 %32
    • Lift and remove the battery.
  3. LG CF360 Rear Speaker Replacement, Back Cover: passo 3, imagem 1 %32 LG CF360 Rear Speaker Replacement, Back Cover: passo 3, imagem 2 %32
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Rear Speaker Replacement: passo 4, imagem 1 %32
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Rear Speaker Replacement: passo 5, imagem 1 %32 LG CF360 Rear Speaker Replacement: passo 5, imagem 2 %32 LG CF360 Rear Speaker Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Rear Speaker Replacement: passo 6, imagem 1 %32
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Rear Speaker Replacement, Rear Speaker: passo 7, imagem 1 %32
    • Use the plastic opening tool to pry the speaker cover off of the phone.
  8. LG CF360 Rear Speaker Replacement: passo 8, imagem 1 %32
    • Use the plastic opening tool to pry the speaker out of the back cover.
Conclusão
Uma outra pessoa concluiu este guia.
Annie White
Membro desde: 10/18/13
262 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-27, Amido Fall 2013 Membro de Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
Membros da 4
Autoria de 19 guias
Um comentário
Where can I buy the replacement parts?
Sarah Birkett - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 252
