Ir para o conteúdo principal
LG BP220 Motherboard Replacement
O que você precisa
  1. LG BP220 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 LG BP220 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Motherboard Replacement: passo 2, imagem 1 %32 LG BP220 Motherboard Replacement: passo 2, imagem 2 %32 LG BP220 Motherboard Replacement: passo 2, imagem 3 %32
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
  3. LG BP220 Motherboard Replacement: passo 3, imagem 1 %32
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
  4. LG BP220 Motherboard Replacement: passo 4, imagem 1 %32 LG BP220 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive, slide it toward you and pull out to remove.
  5. LG BP220 Motherboard Replacement: passo 5, imagem 1 %32 LG BP220 Motherboard Replacement: passo 5, imagem 2 %32 LG BP220 Motherboard Replacement: passo 5, imagem 3 %32
    • Detach the power supply cord from the brown motherboard by pushing the locking clip on the connector, and pulling out.
    • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
    • Remove the power cord from the panel by carefully sliding it upwards from its seating.
  6. LG BP220 Motherboard Replacement: passo 6, imagem 1 %32 LG BP220 Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the two black 3/16” Phillips #2 screws from the backside of the player.
    • One screw inbetween the audio/video jacks
    • One screw to the bottom right of the audio/video jacks
    • With the backside facing you, pull the bottom of the panel towards you and lift to remove it.
  7. LG BP220 Motherboard Replacement: passo 7, imagem 1 %32 LG BP220 Motherboard Replacement: passo 7, imagem 2 %32
    • Handle the motherboards with care. They are fragile.
    • Beware of the capacitors as they may shock you when touched.
    • Remove the the two silver 3/16” Phillips #2 screws from the green motherboard.
    • Remove the one black 3/16” Phillips #2 screw from the brown motherboard
    • Use both hands to carefully lift the motherboard unit away from the player.
Conclusão
5 outras pessoas executaram este guia.
Bart Quicho
Membro desde: 01/13/15
463 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 1-1, Rose Winter 2015 Membro de UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
Membros da 4
Autoria de 3 guias
Um comentário
I need Ic htc lm37102 which is on this lg motherboard. How can i get that. I am not able to find
Email Id abhishek.mishra171983@gmail.com
Please let me know if you have this rgulator ic on my email id.
Thnx
Abhishek
Abhishek Mishra - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 4,522
