Ir para o conteúdo principal
LG Aristo Screen Replacement
O que você precisa
  1. LG Aristo Screen Replacement, Screen: passo 1, imagem 1 %32
    • Turn off the device and make sure you are working on a flat, lit surface.
  2. LG Aristo Screen Replacement: passo 2, imagem 1 %32 LG Aristo Screen Replacement: passo 2, imagem 2 %32
    • Use an iFixit opening tool to pry off the back case.
  3. LG Aristo Screen Replacement: passo 3, imagem 1 %32 LG Aristo Screen Replacement: passo 3, imagem 2 %32 LG Aristo Screen Replacement: passo 3, imagem 3 %32
    • Remove the SD and SIM cards by sliding the cards out with your finger.
  4. LG Aristo Screen Replacement: passo 4, imagem 1 %32 LG Aristo Screen Replacement: passo 4, imagem 2 %32 LG Aristo Screen Replacement: passo 4, imagem 3 %32
    • Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
  5. LG Aristo Screen Replacement: passo 5, imagem 1 %32 LG Aristo Screen Replacement: passo 5, imagem 2 %32
    • Remove the ten screws from the midframe with a Phillips #000 screwdriver.
  6. LG Aristo Screen Replacement: passo 6, imagem 1 %32 LG Aristo Screen Replacement: passo 6, imagem 2 %32
    • Pry up on the screen with a plastic opening tool.
    • Try to avoid using a metal spudger as shown in the images as it has the possibility to damage the screen.
  7. LG Aristo Screen Replacement: passo 7, imagem 1 %32 LG Aristo Screen Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Detach the cables from the press fit connectors.
    • There are four connectors in total, they consist of two on the cameras, one on the ear jack, and the one attached to the motherboard.
    • You can lift them up with you finger or you can use tweezers (optional).
  8. LG Aristo Screen Replacement: passo 8, imagem 1 %32 LG Aristo Screen Replacement: passo 8, imagem 2 %32
    • Gently remove the motherboard.
  9. LG Aristo Screen Replacement: passo 9, imagem 1 %32
    • Replace the screen.
Conclusão
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
Equipe
Gateway, Team S1-G5, Saknee Fall 2019 Membro de Gateway, Team S1-G5, Saknee Fall 2019
GCC-SAKNEE-F19S1G5
4 Membros
1 Guia de autoria
1Comentário do guia
Do i need Loca Glue to replace the outer Glass?
chuck - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 1,508
