Ir para o conteúdo principal
LG Aristo MS210 Front and Rear Camera Replacement
O que você precisa
  1. LG Aristo MS210 Front and Rear Camera Replacement, Battery: passo 1, imagem 1 %32 LG Aristo MS210 Front and Rear Camera Replacement, Battery: passo 1, imagem 2 %32 LG Aristo MS210 Front and Rear Camera Replacement, Battery: passo 1, imagem 3 %32
    • Insert the spudger into the notch on the bottom left side of the phone.
    • Apply light pressure to remove the back cover.
  2. LG Aristo MS210 Front and Rear Camera Replacement: passo 2, imagem 1 %32 LG Aristo MS210 Front and Rear Camera Replacement: passo 2, imagem 2 %32
    • Insert the spudger into the notch located on the bottom middle of the battery.
    • Apply light pressure to remove the battery.
  3. LG Aristo MS210 Front and Rear Camera Replacement, Command Button: passo 3, imagem 1 %32 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: passo 3, imagem 2 %32 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: passo 3, imagem 3 %32
    • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
    • Use the spudger to remove the inner shell.
    • Flip the inner shell over to expose the clips holding the command button.
  4. LG Aristo MS210 Front and Rear Camera Replacement: passo 4, imagem 1 %32 LG Aristo MS210 Front and Rear Camera Replacement: passo 4, imagem 2 %32 LG Aristo MS210 Front and Rear Camera Replacement: passo 4, imagem 3 %32
    • Use the spudger disconnect the three clips holding in the command button as highlighted.
    • Remove the command button.
  5. LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: passo 5, imagem 1 %32 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: passo 5, imagem 2 %32 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: passo 5, imagem 3 %32
    • Use the spudger to disconnect the ZIF connector securing the front-facing camera.
  6. LG Aristo MS210 Front and Rear Camera Replacement: passo 6, imagem 1 %32 LG Aristo MS210 Front and Rear Camera Replacement: passo 6, imagem 2 %32 LG Aristo MS210 Front and Rear Camera Replacement: passo 6, imagem 3 %32
    • Use the spudger disconnect the ZIF connector securing the back-facing camera.
  7. LG Aristo MS210 Front and Rear Camera Replacement: passo 7, imagem 1 %32
    • Remove both the front and back facing cameras.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 185
