Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove Battery
Remove all 6 screws that are on the outer edge of phone
Remove backcasing connected to the rest of the phone.
Remove the phillip screw from the small white box on the top left corner that’s on the battery platform of the phone.
Remove phone sticker and remove screw under the sticker. Now you can remove the motherboard. Be careful with the tether still connected to it.
Remove tether.
Remove the keyboard, and the rubber caps behind the phone.
To the right hand side of where the keyboard was, remove the four screws shown.
Release clips with prying tool and take off the next layer of the phone.
Release the pop-connectors, and the flex cable at the top by the speaker.
. Now you can easily remove the yellow cabling on the phone.
Release jaw connector. Now remove LCD screen. You can now replace the screen.
5 outras pessoas executaram este guia.
