Ir para o conteúdo principal
LG 440G Battery Replacement
  1. LG 440G Battery Replacement, Turn off phone.: passo 1, imagem 1 %32
    • Turn the device off.
    • To do so, press and hold the red button.
  2. LG 440G Battery Replacement, Flip phone.: passo 2, imagem 1 %32
    • Flip the phone over.
  3. LG 440G Battery Replacement, Rear cover removal.: passo 3, imagem 1 %32
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. LG 440G Battery Replacement, Removal of battery.: passo 4, imagem 1 %32
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
Conclusão
3 outras pessoas executaram este guia.
Chris
Membro desde: 02/17/15
185 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-1, Buehl Winter 2015 Membro de Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
Membros da 4
Autoria de 8 guias
5 comentários
The back cover does not move at all.  I even tried to insert the tip of a steak knife on the top, but nothing.  It will not budge.  I have an LG 440G Tracfone.  Since I was not able to check the battery due to not getting the back off, I bought another one.  I just decided to retry but nothing.
carolaerhardt - Responder
Cannot open back of Tracfone 440G to check battery….it does not budge.
Need to replace battery in LG fliphone. Back cover will not slide down Why ? When one cannot open back cover to replace battery it makes the LG flip phone junk.. or as they say in England rubbish.
Hex Ram - Responder
Hex Ram - Responder
Unfortunately, LG does not appear to sell batteries anymore, so if your phone needs a new one you're screwed.
John Dont - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 53
Duração total: 7,494
