Introdução
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to replace the internal circuit board from the device.
O que você precisa
Pry open the back case on the device with a plastic opening tool and remove it.
Dislodge the microSD card from the microSD card slot using your index finger and remove it.
Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
Pry the screen from the internal circuit board with a plastic opening tool and remove it.
