Ir para o conteúdo principal
LG 305C Internal Casing Replacement
O que você precisa
  1. LG 305C Internal Casing Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Internal Casing Replacement: passo 2, imagem 1 %32
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Internal Casing Replacement, Internal Casing: passo 3, imagem 1 %32
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  4. LG 305C Internal Casing Replacement: passo 4, imagem 1 %32
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  5. LG 305C Internal Casing Replacement: passo 5, imagem 1 %32
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  6. LG 305C Internal Casing Replacement: passo 6, imagem 1 %32
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
Conclusão
Ashley Kidwell
Membro desde: 03/20/18
427 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S6-G1, Baechle Spring 2018 Membro de IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 115
