Ir para o conteúdo principal
LG 305C Camera Replacement
O que você precisa
  1. LG 305C Camera Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Camera Replacement: passo 2, imagem 1 %32
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Camera Replacement, MicroSD card: passo 3, imagem 1 %32
    • Dislodge the microSD card from the microSD card slot using your index finger and remove it.
  4. LG 305C Camera Replacement, Internal Casing: passo 4, imagem 1 %32
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  5. LG 305C Camera Replacement: passo 5, imagem 1 %32
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  6. LG 305C Camera Replacement: passo 6, imagem 1 %32
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  7. LG 305C Camera Replacement: passo 7, imagem 1 %32
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  8. LG 305C Camera Replacement, Motherboard: passo 8, imagem 1 %32
    • Pry the screen from the internal circuit board with a plastic opening tool and remove it.
  9. LG 305C Camera Replacement, Camera: passo 9, imagem 1 %32
    • Pry the camera from the internal circuit board with the plastic opening tool and remove it.
  10. LG 305C Camera Replacement: passo 10, imagem 1 %32
    • Detach the camera completely by using the spudger tool to poke through the camera attachment holes.
Conclusão
Ashley Kidwell
Membro desde: 03/20/18
427 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S6-G1, Baechle Spring 2018 Membro de IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 136
