Ir para o conteúdo principal
LG 1010 LCD Screen Replacement
O que você precisa
  1. LG 1010 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 LCD Screen Replacement: passo 2, imagem 1 %32 LG 1010 LCD Screen Replacement: passo 2, imagem 2 %32
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 LCD Screen Replacement: passo 3, imagem 1 %32 LG 1010 LCD Screen Replacement: passo 3, imagem 2 %32 LG 1010 LCD Screen Replacement: passo 3, imagem 3 %32
    • Remove battery and set aside.
  4. LG 1010 LCD Screen Replacement, Front  Cover: passo 4, imagem 1 %32 LG 1010 LCD Screen Replacement, Front  Cover: passo 4, imagem 2 %32
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  5. LG 1010 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove two screws using a Torx T6 screwdriver.
  6. LG 1010 LCD Screen Replacement: passo 6, imagem 1 %32 LG 1010 LCD Screen Replacement: passo 6, imagem 2 %32
    • Pry off the screen front cover with a small flathead screwdriver.
  7. LG 1010 LCD Screen Replacement: passo 7, imagem 1 %32
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  8. LG 1010 LCD Screen Replacement: passo 8, imagem 1 %32
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  9. LG 1010 LCD Screen Replacement: passo 9, imagem 1 %32
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
  10. LG 1010 LCD Screen Replacement, Back Cover: passo 10, imagem 1 %32 LG 1010 LCD Screen Replacement, Back Cover: passo 10, imagem 2 %32
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  11. LG 1010 LCD Screen Replacement: passo 11, imagem 1 %32 LG 1010 LCD Screen Replacement: passo 11, imagem 2 %32
    • Pull the back cover straight off the phone using your thumb and forefinger.
  12. LG 1010 LCD Screen Replacement, Keypad: passo 12, imagem 1 %32
    • Pry off circuit board with a flathead screwdriver.
  13. LG 1010 LCD Screen Replacement: passo 13, imagem 1 %32
    • Pull out flexible keypad.
  14. LG 1010 LCD Screen Replacement, LCD Screen: passo 14, imagem 1 %32
    • The phone should now look like the picture to the left.
  15. LG 1010 LCD Screen Replacement: passo 15, imagem 1 %32 LG 1010 LCD Screen Replacement: passo 15, imagem 2 %32
    • Locate and detach the ribbon cable from circuit board.
  16. LG 1010 LCD Screen Replacement: passo 16, imagem 1 %32 LG 1010 LCD Screen Replacement: passo 16, imagem 2 %32
    • Remove the LCD Screen from the phone case and replace with a new LCD screen.
Conclusão
Equipe
Cal Poly, Team 3-25, Regan Fall 2010 Membro de Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 971
