Ir para o conteúdo principal
LG 1010 Front Cover Replacement
O que você precisa
  1. LG 1010 Front Cover Replacement, Front  Cover: passo 1, imagem 1 %32 LG 1010 Front Cover Replacement, Front  Cover: passo 1, imagem 2 %32
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  2. LG 1010 Front Cover Replacement: passo 2, imagem 1 %32
    • Remove two screws using a Torx T6 screwdriver.
  3. LG 1010 Front Cover Replacement: passo 3, imagem 1 %32 LG 1010 Front Cover Replacement: passo 3, imagem 2 %32
    • Pry off the screen front cover with a small flathead screwdriver.
  4. LG 1010 Front Cover Replacement: passo 4, imagem 1 %32
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  5. LG 1010 Front Cover Replacement: passo 5, imagem 1 %32
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  6. LG 1010 Front Cover Replacement: passo 6, imagem 1 %32
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 3-25, Regan Fall 2010 Membro de Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,001
