Introdução
This guide will help you with the process of replacing the Wi-Fi PCI Card in your device.
Peças
Não são necessárias peças.
  1. Unscrew the two screws using a Phillips #0 screwdriver.
    • Unscrew the two screws using a Phillips #0 screwdriver.
  2. Use a spudger to lift the back cover and remove it from the device.
    • Use a spudger to lift the back cover and remove it from the device.
    • Unplug the two wires that are on the Wi-Fi PCI card (white & black).
    • Unscrew the single screw in front of the Wi-Fi PCI card using the Phillips #0 screwdriver.
    • Remove the Wi-Fi PCI card from the device.
Conclusão
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Todo: 53
