Introdução
This guide will help you replace the hard drive of your device.
Peças
Não são necessárias peças.
  1. Unscrew the two screws using a Phillips #0 screwdriver.
    • Unscrew the two screws using a Phillips #0 screwdriver.
  2. Use a spudger to lift the back cover and remove it from the device.
    • Use a spudger to lift the back cover and remove it from the device.
    • Unscrew the four screws around the Hard Drive using a Phillips #0 screwdriver.
    • Slide the hard drive over and remove it from the device.
Conclusão
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Todo: 85
