Ir para o conteúdo principal
Canon PowerShot A80 LCD Screen Replacement
O que você precisa
  1. Canon PowerShot A80 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
  2. Canon PowerShot A80 LCD Screen Replacement: passo 2, imagem 1 %32 Canon PowerShot A80 LCD Screen Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
    • To access the second screw, rotate the screen 90° so that it faces upwards.
  3. Canon PowerShot A80 LCD Screen Replacement: passo 3, imagem 1 %32 Canon PowerShot A80 LCD Screen Replacement: passo 3, imagem 2 %32 Canon PowerShot A80 LCD Screen Replacement: passo 3, imagem 3 %32
    • Gently remove the front and back covers from the screen.
    • Peel back the plastic circuit cover.
  4. Canon PowerShot A80 LCD Screen Replacement: passo 4, imagem 1 %32
    • Pull the screen away from the base.
    • This will take some force, but remember to handle with care.
    • If a small metal piece between the screen cover and the screen falls out during repair, replace it with the rounded corners facing away from the screen during reassembly.
  5. Canon PowerShot A80 LCD Screen Replacement: passo 5, imagem 1 %32
    • Unplug the ribbon cable connected to the circuit board latch.
Conclusão
4 outras pessoas executaram este guia.
konrad
Membro desde: 01/11/11
220 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-31, Regan Winter 2011 Membro de Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
Membros da 6
Autoria de 12 guias
Um comentário
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 4,098
