Introdução
To isolate the LCD screen, one needs to be gentle with separating parts and removing screws from the camera.
Peças
Não são necessárias peças.
  1. Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
    • Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
  2. Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together.
    • Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together.
    • To get to the second screw, rotate the screen.
    • Gently peel off the front and back cover of the screen.
    • Peel back the plastic cover.
    • Gently pull off the screen from the base.
    • A small metal piece between the screen cover and the screen may fall out during repair. Remember to replace it with the rounded corners facing away from the screen during reassembly.
    • This takes a little force.
    • Unplug the wires that are attaching the screen to the circuit board.
Conclusão
3 outras pessoas concluíram este guia.
konrad
217 reputação
3 Guides authored
Equipe
Cal Poly, Team 7-31, Regan Winter 2011 Membro de Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Membros
6 Guides authored
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Todo: 3,334
