Introdução
The TV turns off by itself after a while or the TV will not start, blown off capacitors could be the source off error.
  1. MAKE SURE THAT YOUR DEVICE IS UNPLUGED!
    • MAKE SURE THAT YOUR DEVICE IS UNPLUGED!
    • Open the case carefully while loosing the marked srews.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Check the power-board. If there are any blown-up capacitors, you should replace them.
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  4. Note: If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
    • Note: If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Conclusão
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
9 outras pessoas concluíram este guia.
eugl18
561 reputação
Autoria de 1 guia
Visualizar Estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 74
Todo: 9,649
