Introdução
If the phone has trouble reading your touch input to its touch screen, the digitizer may be damaged or broken. If that is the case, a replacement is in order. This guide will instruct you on how to safely take apart the device to change out the digitizer.
O que você precisa
Press down on the back of the phone, applying moderate pressure.
Slide the back casing down to separate it.
