Ir para o conteúdo principal
Kyocera Zio M6000 Digitizer Replacement
O que você precisa
  1. Kyocera Zio M6000 Digitizer Replacement, Battery: passo 1, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement, Battery: passo 1, imagem 2 %32
    • Press down on the back of the phone, applying moderate pressure.
    • Slide the back casing down to separate it.
    Pergunte ao FixBot
  2. Kyocera Zio M6000 Digitizer Replacement: passo 2, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 2, imagem 2 %32
    • Remove the back casing to expose the battery.
    • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
    Pergunte ao FixBot
  3. Kyocera Zio M6000 Digitizer Replacement, Motherboard: passo 3, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove the six 3.18 mm screws using a Phillips 00 screwdriver.
    Pergunte ao FixBot
  4. Kyocera Zio M6000 Digitizer Replacement: passo 4, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 4, imagem 2 %32
    • Insert the flat end of the spudger between the front and back panels, and pry it apart by running the spudger along the side to further separate them.
    • Go all the way around, prying as you go, until the back casing completely separates from the rest of the phone.
    Pergunte ao FixBot
  5. Kyocera Zio M6000 Digitizer Replacement: passo 5, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 5, imagem 2 %32 Kyocera Zio M6000 Digitizer Replacement: passo 5, imagem 3 %32
    • Unclip the two flex cables -- a small one located on the left side on the lower half of the motherboard, and a longer one on the right side, higher up.
    Pergunte ao FixBot
  6. Kyocera Zio M6000 Digitizer Replacement: passo 6, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 6, imagem 2 %32 Kyocera Zio M6000 Digitizer Replacement: passo 6, imagem 3 %32
    • Pry out the earpiece speaker using the spudger.
    • Pry out the vibration motor using the spudger.
    Pergunte ao FixBot
  7. Kyocera Zio M6000 Digitizer Replacement: passo 7, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 7, imagem 2 %32
    • Place the flat end of the spudger underneath the digitizer connector and pry it up to disconnect it.
    Pergunte ao FixBot
  8. Kyocera Zio M6000 Digitizer Replacement: passo 8, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 8, imagem 2 %32 Kyocera Zio M6000 Digitizer Replacement: passo 8, imagem 3 %32
    • Remove the sticker to uncover the screws underneath.
    • Remove the six 1.59 mm screws using a Phillips 00 screwdriver.
    Pergunte ao FixBot
  9. Kyocera Zio M6000 Digitizer Replacement: passo 9, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 9, imagem 2 %32 Kyocera Zio M6000 Digitizer Replacement: passo 9, imagem 3 %32
    • Lift the bottom portion of the motherboard away from the front panel.
    • Do not forcefully pull the components apart as there is another connector on the underside of the motherboard attaching it to the panel.
    • Insert the flat end of the spudger in between the panel and motherboard to unfasten the connector.
    Pergunte ao FixBot
  10. Kyocera Zio M6000 Digitizer Replacement, Digitizer: passo 10, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement, Digitizer: passo 10, imagem 2 %32 Kyocera Zio M6000 Digitizer Replacement, Digitizer: passo 10, imagem 3 %32
    • Remove the two rubber pieces from the ends of the panel.
    Pergunte ao FixBot
  11. Kyocera Zio M6000 Digitizer Replacement: passo 11, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 11, imagem 2 %32 Kyocera Zio M6000 Digitizer Replacement: passo 11, imagem 3 %32
    • Remove the red Power button and green Talk button from the bottom of the casing.
    • Remove the trackball, also at the bottom of the casing.
    Pergunte ao FixBot
  12. Kyocera Zio M6000 Digitizer Replacement: passo 12, imagem 1 %32 Kyocera Zio M6000 Digitizer Replacement: passo 12, imagem 2 %32 Kyocera Zio M6000 Digitizer Replacement: passo 12, imagem 3 %32
    • Pry the bottom edge of the bezel with the flat end of the spudger.
    • Carefully run the spudger up the sides until the digitizer is free.
    Pergunte ao FixBot
Conclusão
Scott Nguyen
Membro desde: 09/16/15
522 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 43
Ao todo: 618
