Introdução
If battery power is draining too quickly, or if it is unable to hold a charge altogether, it's time to replace the battery. The task is simple and straightforward, with minimal tools required. Follow this guide to replace the battery for your Kyocera Zio M6000.
O que você precisa
Press down on the back of the phone, applying moderate pressure.
Slide the back casing down to separate it.
Uma outra pessoa concluiu este guia.
