Ir para o conteúdo principal
Kyocera QCP-2035 Microphone Replacement
O que você precisa
  1. Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: passo 1, imagem 1 %32 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: passo 1, imagem 2 %32 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: passo 1, imagem 3 %32
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Microphone Replacement: passo 2, imagem 1 %32 Kyocera QCP-2035 Microphone Replacement: passo 2, imagem 2 %32 Kyocera QCP-2035 Microphone Replacement: passo 2, imagem 3 %32
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Microphone Replacement: passo 3, imagem 1 %32 Kyocera QCP-2035 Microphone Replacement: passo 3, imagem 2 %32 Kyocera QCP-2035 Microphone Replacement: passo 3, imagem 3 %32
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Microphone Replacement: passo 4, imagem 1 %32 Kyocera QCP-2035 Microphone Replacement: passo 4, imagem 2 %32 Kyocera QCP-2035 Microphone Replacement: passo 4, imagem 3 %32
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Microphone Replacement, Microphone: passo 5, imagem 1 %32 Kyocera QCP-2035 Microphone Replacement, Microphone: passo 5, imagem 2 %32 Kyocera QCP-2035 Microphone Replacement, Microphone: passo 5, imagem 3 %32
    • Locate the microphone at the bottom left corner of the phone.
    • using tweezers, Lift the microphone straight out of the phone.
Conclusão
Uma outra pessoa concluiu este guia.
cove
Membro desde: 01/21/15
116 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 5-3, Brown Winter 2015 Membro de USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 223
