Ir para o conteúdo principal
Kyocera QCP-2035 Battery Replacement
O que você precisa
  1. Kyocera QCP-2035 Battery Replacement, Removing Back Cover: passo 1, imagem 1 %32 Kyocera QCP-2035 Battery Replacement, Removing Back Cover: passo 1, imagem 2 %32 Kyocera QCP-2035 Battery Replacement, Removing Back Cover: passo 1, imagem 3 %32
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Battery Replacement: passo 2, imagem 1 %32 Kyocera QCP-2035 Battery Replacement: passo 2, imagem 2 %32
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
Conclusão
Uma outra pessoa concluiu este guia.
Scott Whitney
Membro desde: 01/21/15
301 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 5-3, Brown Winter 2015 Membro de USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 215
