Introdução
Sometimes the volume button gets stuck and you need to replace it/ fix it. This guide will allow you to do that.
O que você precisa
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
Locate the screws holding the trim which are the four side screws on each corner.
Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
Uma outra pessoa concluiu este guia.
