Ir para o conteúdo principal
Kyocera Hydro Vibe Trim Replacement
O que você precisa
  1. Kyocera Hydro Vibe Trim Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Trim Replacement: passo 2, imagem 1 %32 Kyocera Hydro Vibe Trim Replacement: passo 2, imagem 2 %32 Kyocera Hydro Vibe Trim Replacement: passo 2, imagem 3 %32
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Trim Replacement, Trim: passo 3, imagem 1 %32
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Trim Replacement: passo 4, imagem 1 %32 Kyocera Hydro Vibe Trim Replacement: passo 4, imagem 2 %32
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Trim Replacement: passo 5, imagem 1 %32
    • The trim is flimsy.
    • This is what the trim will look like once removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 698
