Ir para o conteúdo principal
Kyocera Hydro Vibe SIM Card Replacement
O que você precisa
  1. Kyocera Hydro Vibe SIM Card Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe SIM Card Replacement: passo 2, imagem 1 %32 Kyocera Hydro Vibe SIM Card Replacement: passo 2, imagem 2 %32 Kyocera Hydro Vibe SIM Card Replacement: passo 2, imagem 3 %32
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe SIM Card Replacement, SIM Card: passo 3, imagem 1 %32
    • Locate the SIM card indicated by the arrows and picture.
  4. Kyocera Hydro Vibe SIM Card Replacement: passo 4, imagem 1 %32 Kyocera Hydro Vibe SIM Card Replacement: passo 4, imagem 2 %32
    • Use the precision tweezer set to safely remove the SIM card.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 653
