Ir para o conteúdo principal
Kyocera Hydro Life Rear-Facing Camera Replacement
O que você precisa
  1. Kyocera Hydro Life Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, imagem 1 %32
    • Flip the phone so that the screen is facing down.
    • Gently remove the back cover with the grip at the bottom of the phone.
  2. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 2, imagem 1 %32 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 2, imagem 2 %32 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 2, imagem 3 %32
    • Use the tab marked "PULL" to remove the battery from its enclosure.
  3. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 3, imagem 1 %32 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 3, imagem 2 %32
    • Remove the six Phillips #00 screws from the back of the enclosure.
    • Use a plastic opening tool to gently remove the plastic piece surrounding the back of the phone enclosure.
  4. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the white sticker.
  5. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 5, imagem 1 %32 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 5, imagem 2 %32
    • Using a pair of pliers, gently pry open the camera ribbon slot.
    • This will not take much pressure to open.
  6. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently remove the camera ribbon.
    • Be very careful not to rip the ribbon. Use tweezers if needed.
  7. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 7, imagem 1 %32 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 7, imagem 2 %32
    • Using a plastic prying tool, gently loosen all 4 corners of the motherboard.
    • Lift the motherboard away from the phone enclosure.
  8. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 8, imagem 1 %32
    • Remove the black sticker.
    • Be careful when removing the sticker. The sticker will need to be replaced after replacing the camera.
  9. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 9, imagem 1 %32
    • Remove the camera from the motherboard.
    • This step requires breaking metal.
    • Only cut along the camera square.
Conclusão
Morgan Marshall
Membro desde: 09/21/18
277 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 218
