Ir para o conteúdo principal
Kyocera Event Rear Assembly Replacement
O que você precisa
  1. Kyocera Event Rear Assembly Replacement, Battery: passo 1, imagem 1 %32 Kyocera Event Rear Assembly Replacement, Battery: passo 1, imagem 2 %32 Kyocera Event Rear Assembly Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Rear Assembly Replacement: passo 2, imagem 1 %32
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Rear Assembly Replacement, Locate the SIM card: passo 3, imagem 1 %32
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event Rear Assembly Replacement, Open slot and remove card: passo 4, imagem 1 %32 Kyocera Event Rear Assembly Replacement, Open slot and remove card: passo 4, imagem 2 %32
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
  5. Kyocera Event Rear Assembly Replacement, Remove the screws.: passo 5, imagem 1 %32 Kyocera Event Rear Assembly Replacement, Remove the screws.: passo 5, imagem 2 %32
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  6. Kyocera Event Rear Assembly Replacement, Remove the back assembly: passo 6, imagem 1 %32 Kyocera Event Rear Assembly Replacement, Remove the back assembly: passo 6, imagem 2 %32 Kyocera Event Rear Assembly Replacement, Remove the back assembly: passo 6, imagem 3 %32
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
Conclusão
Philip
Membro desde: 02/13/15
7 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-4, Michaels Spring 2015 Membro de Ohio State, Team 1-4, Michaels Spring 2015
OSU-MICHAELS-S15S1G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 789
