Ir para o conteúdo principal
Kyocera Event Motherboard Replacement
O que você precisa
  1. Kyocera Event Motherboard Replacement, Battery: passo 1, imagem 1 %32 Kyocera Event Motherboard Replacement, Battery: passo 1, imagem 2 %32 Kyocera Event Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Motherboard Replacement: passo 2, imagem 1 %32
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Motherboard Replacement, Remove the screws.: passo 3, imagem 1 %32 Kyocera Event Motherboard Replacement, Remove the screws.: passo 3, imagem 2 %32
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  4. Kyocera Event Motherboard Replacement, Remove the back assembly: passo 4, imagem 1 %32 Kyocera Event Motherboard Replacement, Remove the back assembly: passo 4, imagem 2 %32 Kyocera Event Motherboard Replacement, Remove the back assembly: passo 4, imagem 3 %32
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
  5. Kyocera Event Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Kyocera Event Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Locate the black L-shaped cover at the top center of the phone.
    • Remove the piece, including the attached ribbon, and set it aside.
  6. Kyocera Event Motherboard Replacement, Disconnect Cables: passo 6, imagem 1 %32 Kyocera Event Motherboard Replacement, Disconnect Cables: passo 6, imagem 2 %32 Kyocera Event Motherboard Replacement, Disconnect Cables: passo 6, imagem 3 %32
    • Use a spudger to carefully disconnect the black cable.
    • Use the spudger to carefully disconnect the brown cable.
  7. Kyocera Event Motherboard Replacement: passo 7, imagem 1 %32 Kyocera Event Motherboard Replacement: passo 7, imagem 2 %32
    • Locate the hook at the bottom of the phone. Use the spudger unlatch the hook connecting the motherboard to the front assembly of the phone.
    • Using your fingers, gently grab the motherboard and pull.
  8. Kyocera Event Motherboard Replacement: passo 8, imagem 1 %32
    • Prior to removing the motherboard, remove the speaker from the top of the device.
  9. Kyocera Event Motherboard Replacement: passo 9, imagem 1 %32
    • Using fingers, remove the motherboard from its casing.
Conclusão
Sydney
Membro desde: 02/11/15
19 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-3, Michaels Spring 2015 Membro de Ohio State, Team 1-3, Michaels Spring 2015
OSU-MICHAELS-S15S1G3
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 841
