Ir para o conteúdo principal
Kyocera Event MicroSD Card Replacement
  1. Kyocera Event MicroSD Card Replacement, Battery: passo 1, imagem 1 %32 Kyocera Event MicroSD Card Replacement, Battery: passo 1, imagem 2 %32 Kyocera Event MicroSD Card Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event MicroSD Card Replacement: passo 2, imagem 1 %32
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event MicroSD Card Replacement, Locate the SIM card: passo 3, imagem 1 %32
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event MicroSD Card Replacement, Open slot and remove card: passo 4, imagem 1 %32 Kyocera Event MicroSD Card Replacement, Open slot and remove card: passo 4, imagem 2 %32
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
Conclusão
Uma outra pessoa concluiu este guia.
graysonmensah
Membro desde: 02/13/15
22 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-4, Michaels Spring 2015 Membro de Ohio State, Team 1-4, Michaels Spring 2015
OSU-MICHAELS-S15S1G4
Membros da 3
Autoria de 4 guias
3 comentários
That's the micro SD slot. That's not for a SIM card.
Carl Jr - Responder
What if there's no metal cover?
Michael ansley - Responder
That's for the sd card not the sim card
gasparesparza9 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 3,054
